 Problème lors du diag VAGCOM.
Problème lors du diag VAGCOM. Empty
MessageSujet: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:19
Voici mon dernier scan....
Sunday,24,July,2011,18:06:15:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 8T0
Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 55 56
5C 62 72 77
VIN: WAUZZZ8K98N000193 Mileage: 51700km/32124miles
01-Engine -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 B HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3210
Revision: --H01---
Coding: 0104002C18072118
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM20TDI03L906022B A01014
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 K HW: 8K0 907 379 K
Component: ESP8 front H03 0180
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 02399 823 56573
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030100
Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H34 0050
Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329HY077518840
Coding: 0000006
Shop #: WSC 02335 785 00200
Part No: 8T0 919 609
Component: E0380 BedienteilH07 0100
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 R HW: 8T1 820 043 R
Component: KLIMA 3 ZONEN H05 0112
Revision: C1000000 Serial number: 0124.08.070038
Coding: 34080000
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000036843
Coding: 2600D0914014AF010001000300001D0D4F1C030800010141000000
Shop #: WSC 79936 146 59471
Part No SW: 8K1 955 119 HW: 8T1 955 119
Component: WWS 210907 H06 0060
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0002
Coding: 025028
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 A
Component: MP3-Changer H41 0390
Revision: 00041002 Serial number: AUZ5ZBG4030177
Shop #: WSC 00000 000 00000
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330727002076
Coding: 000003
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H23 0409
Serial number: 0038JD113YVR
Coding: 30343434363030303030554A304C384B3053
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304GHA0006N
Coding: 000096
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H13 0221
Revision: 00000000 Serial number: 7BX23W3A7
Coding: 0F1D080042000008030000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 G HW: 8T0 907 468 G
Component: GW-BEM 5CAN-M H08 0084
Revision: FB102034 Serial number: 3400F077308002
Coding: 000003
Shop #: WSC 79936 146 94435
Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H49 1060
Revision: 00000000 Serial number: 364E-077685355
Shop #: WSC 79936 123 94435
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H09 0170
Revision: Serial number: 0000006645907
Coding: 011C02205000410001
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0106754192
Coding: 01000660003904C0032001
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 P HW: 8T0 035 223 A
Component: DSP STD H07 0250
Revision: 23S00000
Coding: 010101
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H09 0170
Revision: Serial number: 0000006641747
Coding: 011C02205C00410001
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000017605
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394HX077800753
Coding: 0000001
Address 5C: Lane Maintain. Labels: None
Part No SW: 8K0 907 217 A HW: 4E0 907 217 C
Component: J759 LDW 0070
Revision: 00H06006 Serial number: 8002077190000B
Coding: 0000001
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006640754
Coding: 010C02204000210001
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0168
Revision: Serial number: 00000006607177
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005009880
Coding: 0010910
End ---------------------------------------------------------------------
Comme vous le voyez, j'ai une erreur sur le module 08 : Ventilation auxiliaire
Je pense qu'il est apparu lorsque je l'ai activé, je n'arrive pas à l'acquitter alors que la ventilation auxiliaire marche très bien chez moi.... scratch
Ensuite, j'avais un défaut sur le Lane Assist, module 16 et 5C. J'ai fait plusieurs scans et reset des défauts avant de pouvoir l'acquitter. Le problème était que quand j'enclenchais le Lane Assist, y'avais pas de soucis mais dès que je le déclenchais en franchissant la ligne, il se mettait en erreur (problème apparemment avec le moteur vibrant, problème apparu d'ailleurs quand j'ai changé mon volant je pense....) scratch scratch scratch
Voici ce que le scan me mettait :
Coding: 000096
1 Fault Found:
02795 - Steering Wheel Vibration Motor (V331)
007 - Short to Ground - Intermittent
Coding: 0000001
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
013 - Check DTC Memory - Intermittent
Je referais un test sur route et on verra si le défaut revient. De toute manière, je prends mon portable pour le rassemblement de Jeudi, je pense que ca va servir.... lol!
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:24
J'ai le même défaut que toi... Qui apparait de temps en temps... Mais moi il me dit que c'est le pulseur d'air... Pourtant ça marche nickel..
Problème lors du diag VAGCOM. Olive111
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:27
Ouai, c'est bizarre, y'a des trucs que je pige pas parfois.... scratch
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:30
Je crois que si nous scannons notre voiture toutes les semaines, il y aura toujours un défaut...
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:43
Avant le dernier scan, j'avais aussi ces défauts :
Coding: 01000620003904C0032001
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 78
Mileage: 48898 km
Time Indication: 0
Date: 2011.06.19
Time: 19:35:00
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 78
Mileage: 48898 km
Time Indication: 0
Date: 2011.06.19
Time: 19:36:03
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 13
Reset counter: 161
Mileage: 48898 km
Time Indication: 0
Date: 2011.06.20
Time: 10:27:07
Je n'ai plus le défaut mais j'ai toujours ma trappe qui ne verrouille plus, tu peux me dire : bienvenue au club... mdr
Et pour la lumière du coffre : ????????? Je pige pas.....
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:48
C'est parce que tu as mis une led... J'avais cette erreur aussi, et puis hop envolée!
Voici le mien de ce jour...
Address 01: Engine (J623-CAGB) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JP HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3175
Revision: 11H01---
Coding: 0104002C18072018
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022JP A01004
ROD: EV_ECM20TDI03L906022JP.rod
VCID: 7CFCF6AE00B171FC
Readiness: 0 0 0 0 0
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Coding: 160500
VCID: 78F4EABE34895DDC
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Revision: 00002001
Coding: 030100
VCID: 2E580CE6864D536C
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0116.07.080855
Coding: 34000000
VCID: 4280485622D5C70C
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000082216
Coding: 2600D0914034AF000001000000001D0D0F1C030800010101000000
VCID: 2F6611E281475A64
Component: WWS 280608 H06 0060
Coding: 00FD11
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52940819804306
Coding: 000003
VCID: 3A7030B64A058FCC
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:51
cpojuste C'est beau tous ces "OK".... lol!
Pour la led, c'est vrai que j'en ai une dans le coffre mais bon, j'en ai dans toute la voiture, va comprendre.....
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:52
Oui mais je te précise que 15 minutes avant, j'en avais une... Lollll
MessageSujet: Re: Problème lors du diag VAGCOM.   Problème lors du diag VAGCOM. Icon_minitimeDim 24 Juil - 19:59
mdr Je comprends mieux maintenant..... lol!
» Problème lors de la décoche
» Problème lors de l'écriture d'un message [RÉGLÉ]
» Problème de serrage de la cassette
» Trés mauvaise qualité lors de l'export avec Gopor Studio
» naviculaire
