 Problème direction + ESP + TMPS.
Problème direction + ESP + TMPS. Empty
MessageSujet: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeMar 26 Fév - 19:28
Aujourd'hui au matin allumage du voyant de directiuon : probleme direction dynamic : erreur systeme.
et ce soir probleme du dispositif pression des pneu et probleme ESP.
Voici le scan si quequ'un y a une idée, demain j'irais au garage.
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 1010
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0002
Revision: --H01---
Coding: 0104002C180F0118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02002
ROD: EV_ECM30LTDIA5.rod
VCID: 2E570A8BC533
2 Faults Found:
4698 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - Open or Short to Plus
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 60784 km
Date: 2013.02.26
Time: 18:10:15
4699 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 60784 km
Date: 2013.02.26
Time: 18:10:15
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 N HW: 8K0 907 379 N
Component: ESP8 quattro H03 0210
Revision: -------- Serial number: --------------
Coding: 1B6D00
VCID: 448348237BBF
2 Faults Found:
03110 - Active Steering Control Module (J792)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 224
Mileage: 60774 km
Time Indication: 0
Date: 2013.02.26
Time: 08:14:19
Freeze Frame:
Hex Value: 0x7900
Hex Value: 0x4006
Hex Value: 0x120C
Hex Value: 0x16B8
Hex Value: 0x00FF
03159 - TPMS Functionality in ESP
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 60799 km
Time Indication: 0
Date: 2013.02.26
Time: 18:34:39
Freeze Frame:
Hex Value: 0x2700
Hex Value: 0x4206
Hex Value: 0x121A
Hex Value: 0x0DB9
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030100
VCID: 306B14F3DF07
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H35 0052
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 59939 km
Time Indication: 0
Date: 2013.01.30
Time: 15:23:28
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 E HW: 4E0 035 729
Component: Interfacebox H43 4690
Revision: 00000000 Serial number: 329KZ077527505
Coding: 0040006
Shop #: WSC 00000 000 08192
VCID: 3B7133DF0641
Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 Q HW: 8T1 820 043 Q
Component: KLIMA 3 ZONEN H05 0120
Revision: C0000000 Serial number: 0122.11.070400
Coding: 36000000
VCID: 3F8947CF1259
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 229
Mileage: 59899 km
Time Indication: 0
Date: 2013.01.17
Time: 17:55:16
Freeze Frame:
Voltage: 14.30 V
Temperature: 9.0°C
Temperature: 17.0°C
Count: 11252
Count: 20000
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0253
Revision: 04021001 Serial number: 00000000048711
Coding: 260050914014AF311601000000001D0D0F9C834800010141000000
Shop #: WSC 00963 264 93297
VCID: 2F69178FC239
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119
Component: WWS 211107 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0002
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 B HW: 8T1 035 110 A
Component: MP3-Changer H41 0380
Revision: 00041003 Serial number: AUZ5ZBG4044946
Shop #: WSC 00000 000 00000
VCID: 295DF997FCDD
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230733408752
Coding: 100003
VCID: 397D29D70C7D
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD121ZRN
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
VCID: 3C7330C3034F
Driver's Airbag Crash Sensor:
Serial number: 6334MSME31537A49F
Passenger Side Airbag Crash Sensor:
Serial number: 6344MSME315365322
Driver's Rear Airbag Crash Sensor:
Serial number: 6352QSME485012030
Passenger's Rear Airbag Crash Sensor:
Serial number: 6362QSME424D792DW
Driver's Front Airbag Crash Sensor:
Serial number: 63732SME44221B6F1
Passenger's Front Airbag Crash Sensor:
Serial number: 63832SME44301A0BX
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KBA000Y3
Coding: 000016
Shop #: WSC 00990 264 88796
VCID: 3E773ACB1553
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H14 0214
Revision: 00000000 Serial number: 7BX10ZWC7
Coding: 0F04090023000008040000
VCID: 2D550D87C835
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07B078039
Coding: 000003
Shop #: WSC 00963 264 85468
VCID: 448348237BBF
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 230
Mileage: 59939 km
Time Indication: 0
Date: 2013.01.30
Time: 15:23:29
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 A HW: 8K0 907 144 A
Component: DYNAMIKLENK. H05 0322
Revision: 50000003 Serial number: --------------
Coding: 0C0000
Shop #: WSC 00837 264 90646
VCID: 2D550D87C835
2 Faults Found:
03222 - Initialization Sensor in Steering Motor
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 60774 km
Time Indication: 0
Date: 2013.02.26
Time: 08:14:19
Freeze Frame:
Count: 129
Count: 51
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 4
Mileage: 60774 km
Time Indication: 0
Date: 2013.02.26
Time: 08:14:19
Freeze Frame:
Count: 56
Count: 1
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H50 1060
Revision: 00000000 Serial number: 333K$077528945
VCID: 3B7133DF0641
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006701105
Coding: 011C02205000410001
VCID: 3F8947CF1259
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 59939 km
Time Indication: 0
Date: 2013.01.30
Time: 15:23:33
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0107809663
Coding: 01000620003904C0012001
Shop #: WSC 06342 000 00000
VCID: 306B14F3DF07
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 59939 km
Time Indication: 0
Date: 2013.01.30
Time: 15:23:28
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 M HW: 8T0 035 223 C
Component: DSP Prem H12 0280
Revision: 00H12003 Serial number: 34813001105903
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 387B2CD33777
1 Fault Found:
02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 59939 km
Time Indication: 0
Date: 2013.01.30
Time: 14:44:17
Freeze Frame:
Voltage: 12.10 V
Temperature: 24.0°C
Temperature: 25.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H09 0170
Revision: Serial number: 0000006677948
VCID: 3E773ACB1553
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 230
Mileage: 59939 km
Time Indication: 0
Date: 2013.01.30
Time: 15:23:33
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000032573
VCID: 2F69178FC239
1 Fault Found:
00381 - Databus Instrument Cluster
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 59290 km
Time Indication: 0
Date: 2013.01.01
Time: 05:09:04
Freeze Frame:
Voltage: 12.50 V
Count: 81
Speed: 0.0 km/h
Hex Value: 0x4063
Hex Value: 0x0008
Hex Value: 0x1010
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 33611BFF2E11
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336K$077526926
Coding: 0000001
VCID: 2E570A8BC533
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006662475
Coding: 010C02204000210001
VCID: FF0987CFD2D9
1 Fault Found:
02123 - Door Warning Light / Entry Light
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 230
Mileage: 1048575 km
Time Indication: 0
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000006681057
VCID: FEF77ACBD5D3
End ---------------------------------------------------------------------
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeMar 26 Fév - 19:48
Tu penses que ça peut être lié à ton accident?
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeMar 26 Fév - 20:48
En tous cas, il y a plein d'erreurs liés à la porte arrière...
Problème direction + ESP + TMPS. Olive111
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeMar 26 Fév - 21:00
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeMar 26 Fév - 21:48
Donc les erreurs de la portiere arriere datent de la reparation, ils ont pas du vider les défauts...
Pour aujourd'hui c'est ca le probleme:
Sujet: probleme direction + ESP + TMPS Aujourd'hui à 19:28
Revision: --H01---
VCID: 2E570A8BC533
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 60784 km
Date: 2013.02.26
Time: 18:10:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 60784 km
Date: 2013.02.26
Time: 18:10:15
Coding: 1B6D00
VCID: 448348237BBF
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 224
Mileage: 60774 km
Time Indication: 0
Date: 2013.02.26
Time: 08:14:19
Freeze Frame:
Hex Value: 0x7900
Hex Value: 0x4006
Hex Value: 0x120C
Hex Value: 0x16B8
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 60799 km
Time Indication: 0
Date: 2013.02.26
Time: 18:34:39
Freeze Frame:
Hex Value: 0x2700
Hex Value: 0x4206
Hex Value: 0x121A
Hex Value: 0x0DB9
Hex Value: 0x00FF
Coding: 0C0000
VCID: 2D550D87C835
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 8
Mileage: 60774 km
Time Indication: 0
Date: 2013.02.26
Time: 08:14:19
Freeze Frame:
Count: 129
Count: 51
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 60774 km
Time Indication: 0
Date: 2013.02.26
Time: 08:14:19
Freeze Frame:
Count: 56
Count: 1
A ce que j'ai compris il y a un probleme d'initialisation du capteur de la direction dynamique.
Pour l'ABS je regarde.
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeMer 27 Fév - 14:58
Pas sur car ca date de 3 semaines apres l'accident, mais quelle coincidence....
Je suis passé dans un CC ce matin et pour l'instant il faut faire un calibrage du recepteur de la direction dynamique. En fait celui-ci a une erreur et comme l'ESP, en cas de besoin, prend le controle de la direction dynamique alors la voiture a mis en défaut aussi l'ESP et la pression des pneu. Tout fonctionne ensemble.
Dans cette CC rendez-vous que le 15 Mars et dans le garage qui m'a réparé la voiture rendez-vous dès Lundi. Ce qui m'embete c'est que ce garage, qui est "groupe Volkswagen", est celui qui m'avait fait une mer*e sur la purge de refroidissement....donc soit j'attend ou alors je retourne dans ce garage.
En fait ils vont recalibrer la direction et si tout ce passe bien alors pas d'autres frais, sinon peut etre un capteur ou d'autres elements de la direction a changer. Dans les 3 CC du coin c'est la premiere fois qu'ils ont le cas.
Pendant qu'ils y sont je vais peut etre faire une géometrie.
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeSam 2 Mar - 20:31
Rendez-vous Lundi matin au garage, en esperant que le probleme soit réglé aussitot....
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeLun 4 Mar - 11:12
J'espère pour toi. Ça rends fou ces défauts !
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeLun 4 Mar - 12:42
Voila probleme résolu pour 196€....
Reglage géometrie et réglage du capteur de la direction.
Aucune idée d'ou ca peut venir mais bon maintenant tout marche bien.
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeLun 4 Mar - 13:25
Excellente nouvelle Wink
MessageSujet: Re: Problème direction + ESP + TMPS.   Problème direction + ESP + TMPS. Icon_minitimeLun 4 Mar - 16:53
Wink
» Problème Direction stronglight à aiguille sur VK1
» appui sur le mors problème
» Problème direction 401
» comment enlever le jeu dans la conduite d'un apex ?
