 [CIRE Carnauba] Polish Angel, Concours de Beauty
MessageSujet: [CIRE Carnauba] Polish Angel, Concours de Beauty   Sam 1 Juin - 7:38
Polish Angel Concours De Beauty
Citation :
Description
CONCOURS DE BEAUTY high Carnauba content provides a breathtaking surface reflection, gloss and smoothness. Bright and metallic paints will benefit largely from the white carnauba which provides a stunning proportion of surface reflection. With an extremely long durability it will keep your bodywork protected from dirt, UV rays and all other harmful elements.
CONCOURS DE BEAUTY is presented in a Italian Murano air sealed glass pot, protected by a silver satin pouch which includes our 'finishing planet applicator'. Two pieces of GENUINE SWAROVSKI CRYSTALS are implemented on the lid. The goods are shipped out in an elegant black carrying case. The wax should be stored in a cool and dry environment.
Tip
We recommend pre-treating the surface with the POLISHANGEL®️ ESCLATE LOTION to ensure a clean surface for the wax to bond to
✓ Suited for bright and metallic paints
✓ Soft texture
✓ Caribbean scent of walnuts, kiwi and vanilla
✓ Achieves a deep reflection
✓ Rich and wet shine
✓ High UV Protection
✓ No streaking
✓ No discolouration on plastic parts
✓ Suitable for hand application
✓ Easy on, easy off
✓ 150ml
Application
1. Make sure paintwork is dry, clean and prepared
2. Apply a thin, even layer of product with cosmic applicator pad
3. Leave to cure for 30 minutes
4. Buff off with dry micro fibre towel
Voici donc la Concours De Beauté de chez Polish Angel , c'est la cire d'entrée de gamme de la marque
Pour l'instant, il semblerait que Polish Angel l'ai retirée du marché , mais elle est encore disponible sur certains shops à des prix très intéressant de 50€ les 150ml à 85£ les 150 ml en fonction du packaging
http://carproductstested.com/exterior-product-reviews/polish-angel-concours-de-beauty-review/
http://www.polishangel.co.uk/products/polish-angel-concours-de-white-crystal-beauty
Elle était disponible dans un emballage plus basique à la base mais au fur et à mesure le packaging à quelque peu évolué vers un pot en verre avec 2 cristaux Swarovski véritables , la cire sent bon un savant mélange de noyer des caraïbes , de kiwi et de vanille.
Il semblerait d'après les infos que j'ai qu'elle contienne environ 60 % de carnauba de "Grade one" ,ce qui la place déjà très haut pour une entrée de gamme , on est au dessus d'une Onyx à 30% qui est l'entrée de gamme de chez Swissvax ou d'une Zymol Creme à 37%
Concernant sa durée dans le temps , elle est annoncée à 6 mois mais là encore fois tout dépend des conditions d'utilisations du véhicule et de la mise en oeuvre du produit
Concernant l'application, il est recommandé de passer l'Esclate Lotion comme cleaner ou le Palm Balm , elle ne laisse aucune traces blanches sur les plastiques
Le temps de pose de la cire est de 15 à 30 minutes et il faut compter 30 minutes entre chaque couches afin d'optimiser la prise de la cire
Concernant l'application , c'est un jeu d'enfant avec un pad "planet applikator" , la cire étant bien dure il suffit de faire un petit quart , voir demi tour pour chargé le pad , puis elle s'étire d'une façon remarquable
Le buffing est très facile et sans poussières , voici quelques images sur une Mito qui n'a pas été polie
Le rendu est juste brillant et clair à souhait avec une belle petite profondeur
Juste un coup d 'esclate lotion qui reduit déjà largement les mr et supprime l'oxydation Very Happy Very Happy , il reste donc quelques défauts Rolling Eyes
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Sam 1 Juin - 9:04
Merci John, que de beaux reflets.
Cette cire est identique a la majesté de passion?
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Sam 1 Juin - 11:16
j'aime bien ce rendu , çà fait bien ressortir les paillettes ...
de beau reflets miroir...
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Sam 1 Juin - 14:35
pt1 ça me donne envie... Très propre cette petite alfa. Bravo john. Tu vas encore gagner plein de produits PA avec cette promo... Razz (je déconne)
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Sam 1 Juin - 18:36
Merci lers gars , normalement si j'ai bon souvenir elle est un cran en dessous de la majeté de passion c'est l'entrée de gamme
Et pour info , même si c'est dit en rigolant ....je paye mes produits PA comme tout le monde , je n'ai rien à y gagner sauf votre respect et vos comm Very Happy
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Dim 2 Juin - 22:09
On en doute pas John, c' est cool d' avoir des retours...
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Dim 2 Juin - 22:14
john50 a écrit:
je n'ai rien à y gagner sauf votre respect ...Very Happy
tu l'a ... Wink
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Dim 2 Juin - 22:22
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Lun 3 Juin - 6:02
MessageSujet: Re: [CIRE Carnauba] Polish Angel, Concours de Beauty   Lun 3 Juin - 8:00
Whaouu !! affraid
